SAE J2954 - Wikipedia
The Wikipedia article says "demonstrated efficiency of around 85%", which presumably is just the efficiency of the inductive coupling system rather than the efficiency of the entire internal charging system.
This is far below the efficiency of wired chargers. Losing an extra 15% efficiency is a big deal, and that 15% turns into quite a bit of heat at a 11 kW charge rate. I don't mind inefficient wireless charging when it's only wasting a few watts while charging my phone. I do mind losing that power when it's measured in kWh.
