Looks like my Powerwalls updated to 1.29.0 today, directly from 1.26.0. Latest release notes are still from 1.27.0.
I haven't noticed any differences yet.
Mine did the same thing today. I was at 1.28 this morning, and now 1.29.Looks like my Powerwalls updated to 1.29.0 today, directly from 1.26.0. Latest release notes are still from 1.27.0.
Mine also get updated today from 1.26 to 1.29.
I notice a strange behavior when using TBC-B mode in 1.26. Hope it will be fixed in 1.29.
Do you have solar? If so, it won't charge from grid unless Storm Watch is active.I use the TBC-CS (Cost Savings) mode. I haven't noticed anything specific yet, but then again I probably should check after 3 to 4 says of letting it run.
Question; If I'm down to 25% which is my reserve for Power Outage, could I just set it to Back-up only to charge just once off the grid during Non-Peak and then switch it back to TBC-CS?
If connected to solar, you can't charge it that way in the United States. It would be a nice feature to have on occasion.I use the TBC-CS (Cost Savings) mode. I haven't noticed anything specific yet, but then again I probably should check after 3 to 4 says of letting it run.
Interesting. I wonder if I turned off my solar if I could manually charge the Powerwalls from the grid.I do have solar, 10 panels @ 325 each, and two Powerwalls.
One thing I noticed a few weeks back. My Nurio and CT that monitored the SolarEdge inverter went offline (they went bad), so for the few days it was charging my Powerwall on the grid during non-peak, while sending back unused solar to the grid during Partial Peak and Peak hours. Once my Neurio was replaced, everything went back online.
I have two Neurio because I needed more than 4 ports.
Neurio #1
Port 1 - Load Center
Port 2 - Tesla Wall Connector (because it's not on the load center)
Port 3 - Powerwall #1
Port 4 - Powerwall #2
Neurio #2
Port 1 - Solar Edge Inverter
Port 2 - Solar Edge Inverter
I guess when one goes offline, the system thinks you only have Powerwall (no solar), so then it charges the Powerwall off the grid during non-peak.
I'm curious if that was a fluke, or if that is indeed a fallback in the event your panels go offline for an extended duration. you revert back to just having a Powerwall and that configuration opens up in the app.
MorrisonHiker, I haven't seen the behavior you described, but good to know.
I noticed today my powerwalls are now at 1.32. I wonder if it can now handle excess solar settings from the app. Let's check the release notes Tesla has posted for explanations of your observed behavior and changedsin 1.32. Oh wait... Tesla release notes are useless. 1.32 isn't even posted on Software Updates | Tesla as of this writing, and even if they were, they don't list anything useful.
