I wouldn't do it. Lithium batteries are more sensitive to operating temperatures than lead acid. This is why the Li-Ion HV pack has a state-of-the-art thermal control system in place. The 12v has nothing to regulate it's temperature. It's exposed to whatever ambient temperature exists on that day/night. Being as your location is listed as "Denver" I would guess that this could be especially troublesome in the winter time. This is why I just run a lead acid 12v and call it a day. Especially since all it does is power your 12v accessories so it's night like you need cold cranking amps to turn over a 6.0L high-compression gasser engine in the dead of winter in negative temps or anything like that.
Agreed up to the point where you proactively replaced your 12v battery. With the warning system on these Teslas you likely will start getting a warning that it's failing months in advance giving you plenty of time before a full failure. In fact, that's one of my big complaints is it's almost too sensitive to voltage drops but I prefer this over traditional cars that tell you by not starting in the dead of winter often times as their first symptom. So I see no real reason to replace a perfectly good 12v battery.Same thoughts here. I really thought about it(12v Li-Ion). I drive up and around Lake Superior to visit friends in the winter.
More reading it turned out unless it has some type of temp control it could not behave when you want in extreme cold as mentioned above. Weight savings might mean having to plug in a battery blanket for your LI-ion 12V.
That is one of the issues I am having moving to LI-Ion on my trailer. Different application I know. Must have a conditioned battery for longevity and accepting safe charge. Warming blankets etc...
I just did a proactive replacement of my 12v in December for my S. Was coming in on 100k and it had been fine. Didn't feel like finding out it didn't work without warning. Some don't get the warning. Most do.
The one I was considering has a BMS built in. There is a definite cost difference.I wouldn't do it. Lithium batteries are more sensitive to operating temperatures than lead acid. This is why the Li-Ion HV pack has a state-of-the-art thermal control system in place. The 12v has nothing to regulate it's temperature. It's exposed to whatever ambient temperature exists on that day/night. Being as your location is listed as "Denver" I would guess that this could be especially troublesome in the winter time. This is why I just run a lead acid 12v and call it a day. Especially since all it does is power your 12v accessories so it's night like you need cold cranking amps to turn over a 6.0L high-compression gasser engine in the dead of winter in negative temps or anything like that.
It also adds one more point of failure to what would otherwise be a simple solution.The one I was considering has a BMS built in. There is a definite cost difference.
As far as Teslas having a 12 volt battery fail without warning, I've got to working theory on that based on personal experience...Fair enough. My time stranded is never worth a dead battery. Did mine prior to a 7k road trip in middle of winter. Didn't want to hear Tesla Roadside blame a bad 12v.
There have been posts that where the 12v went without warning. For me that could be in Radisson, Quebec. Spare tires and Tesla 12v batteries are hard to find. Could cost me a day. Could cost me a week and a grand for tire or part.
Have done that every 3 years on every car. Nominal when you think of cost. They don't throw away the battery. So do I pay a bit more? I guess, but the battery was replaced what 6 months prior to it dying? So over my car driving lifetime I bought 4 extra 12 v batteries. I never have to think about those cold cranking amps.
More or less if you take giant road trips. Those lights that go off change the mood. For minimal dollars in advance I can keep that mood.
How do they make and sell any new cars if this is the case? Maybe they are just prioritizing what they do have for new cars?I tried to buy a 12v battery at my SC. Sorry, none for months, China not shipping now. Stop by next month.
LTO ?LTO chemistry solves the temperature issues down to neg 30 degrees Celsius for charge/drain at massive C rates. Also these cells last 'forever'. Five 2.3v cells in series makes up a lead-acid replacement pack since the nominal voltage is lower with LTO.
Can you explain more about that? The high V spikes?Any Li-Ion solution is impossible now since the high voltage spikes that Tesla superimposes on the DC-DC output will over time destroy any chemistry lithium battery, sad to say.
