Even though I read and heard that the 15 millimeter spacers will work on my vehicle, they don’t. The factory studs stick out too long. I’m not willing to trim the OEM studs or drill out deeper dimples in the wheel.
I’m thinking that 20 mm spacers would be the smallest that would work. I will do 25 mm on the rear.
I’m thinking about doing non-studded spacers, and just use the factory lug and Lugnuts.
Question- would a 10 mm type 2 spacer totally cover up the hub center lip? Is there a type 2 spacer that has a hub on it that someone has used on their model S?
