The Model Y Unveil cars had either 19" or 20" wheels with corresponding tires that were 1.6" larger in diameter than Model 3. They were also 255 width vs 235 on Model 3.
To match the width and diameters, tires sizes would be:
255/50R18
255/45R19
255/40R20
The larger two sizes have plenty of options listed on tirerack.com; 43 and 55 options respectively. However, 255/50R18 only has one option listed. It is not a standard tire size.
I see three scenarios:
What does this mean? The EPA ranges that we've seen for the Model Y are determined with the standard wheel and tire. Therefore, the 19 and 20" wheel/tire combinations will have a larger impact on range than they do on the Model 3. This is due to the extra 20mm width resulting in more drag.
The saving grace may be the higher total drag of the Model Y. The tire drag by itself will be a smaller portion of the total drag due to the Model Y's larger frontal area.
255/50R18
255/45R19
255/40R20
- Tesla convinces a manufacturer to build a tire in that size, like a Michelin Primacy MXM4 with TO spec
- Tesla uses a 19" wheel and tire as the standard size
- Tesla uses a 235/55R18 tire as the standard size, this is the same diameter just narrower.
