I believe it was ~402 miles when new on 19” wheels. ~375 ish on 21s.
If you have 21s, then an observed range of 359 in 2023 is very normal.
Even if you have 19s, 359 miles is ~11% degradation, which is not out of the range of normal.
I have 19 inch wheels on the MS…+1
What wheels do you have set in the car's configuration? 19 or 21?
At 100% I only get to 359 miles; however, my 2020 LR+ has 85,000 miles on it…I also have the same car, it charges to 376 miles when I charge to 100%. I have 37k miles
That’s little less than 11%, I would say that’s normal. I would say you should try cycling you battery 90 -> 10% a couple of times and see if it improves a bitAt 100% I only get to 359 miles; however, my 2020 LR+ has 85,000 miles on it…
Is that amount of degradation normal for a 3 yo battery with this amount of miles?
Do you mean run the charge from 90 to 10%?That’s little less than 11%, I would say that’s normal. I would say you should try cycling you battery 90 -> 10% a couple of times and see if it improves a bit
Custom Range | Current Range | Range Loss | Percent Loss |
402 | 379.69 | 22.31 | 5.55 % |
