2021 MS refresh new purchase questions
Hi guys I have a few questions just purchased 2021 refresh with 5k miles
1. Tire at front are Mitch sports 265/35/21
Rear is 295/30/21
Is this correct are they supposed to be different? I am more interested in the 35 v 30 number
Also I am in Chicago so can we square them up or not and if not can I go to sidewall 40 all around
2. Battery at 90% was 329 miles so full estimate 362 miles at 100%
I thought it was 400 epa?
See pictures of car and tires
A new Model S LR has an EPA range of 405 miles at 100%. This degrades over time and use. Most owners see a loss in the first year with 2-3% typical, and then about 1% a year thereafter. The range numbers between 100% and 0% are calculated and purposely tend to drift downward over time. If the car is 2 years old, there will be some drift and you can't assume what you see at 90% is accurate anymore for what the real range is.
A lot more details here: Range University – TeslaTap
Reactions: saj070
Upvote 0
Notice when I go over bump left passenger seat ratle nothing significant but it noticed if I listen fo it
Any recommendations or just open a ticket
Sorry too many questions but so excited my forst model s refresh just want to make sure not missing anything things
Lots of reading and searching to do lol
Upvote 0
Lower the rear seat and wrap the entire center portion of metal U-latch with couple layers of gaffers (or electrical) tape.
I would avoid Service Center for any minor items, as they probably won’t fix and it’s not worth time / risk of having your car sit in their facility. Mobile service can be great if solvable by them.
Reactions: saj070
Upvote 0
Thank you I will try that just to be clear wrap around the U and then latch the seat? Will the seat latch back into theU?
Upvote 0
Might have to slam seat back, but it will latch.
Thank you so much just wrapped some double sided thick tape few turns both sides
I try to push and pull the seat seems pretty sturdy will take it for a drive to confirm
Pictures before and after for other member pictures are more than thousand words
If you did not post I would still be contemplating exactly where to wrap it
Upvote 0
