I have the Power Frunk V5 for my Model Y and it worked fine until I could not close the frunk from the app. I am able to close from the screen in the car or the button in the frunk. Could the Tesla update cause this?
TIA,
Guy
Thanks that worked for me!!I have the same issue, I'm currently using Tessie to close as a workaround.
Use Tessie and that will be an alternative to the Tesla app until a resolution.Following thread. Just noticed this happened to me too. App will open but not close the Frunk. I can only close it from the on screen display now.
Thank you! Added “Open Tesla Frunk” using Shortcuts on my iPhone is another work around.If you are using IOS, using widget still working for closing the frunk as well as custom shortcut that uses Tesla API
Can confirm installing 4.24 will allow you to close and open frunk
Thanks for confirming. Does the widget work on Android like it does for iOS on the latest version or is the only hope to rollback to 4.24?
No longer sends the open frunk command if the frunk is already open, which has the unfortunate side effect of disabling the remote close functionality of the power frunk kit we installed. Not happy...![]()
