Air Suspension and Body Roll
Discussion in 'Model S' started by grisnjam, Dec 29, 2011.
Tags:
  1. grisnjam
    grisnjam P6316
    Austin, Texas
    I am wondering about the air suspension option on the Model S and body roll and pitch. Were the tour cars equipped with the air suspension? Anyone ask about how pronounced the reduction in boll roll the air suspension provides? I am less interested in the aerodynamic against then increased handling.
    Thanks,
  2. WhiteKnight
    WhiteKnight _____ P85 #549 _____ Sig Red / Sig White
    Atlanta
    #2 WhiteKnight, Dec 30, 2011
    My understanding is the test ride cars on 10/1 did have the Air Suspension. Unfortunately only the employees at Tesla know what a difference Air Suspension makes because they're the only ones who have driven the Model S with and without it.
    In general I believe Air Suspension has the potential to greatly improve handling, ride quality and aerodynamics (by lowering the car on the highway.)
    Because of the low center of gravity due to the location of the battery pack the Model S should perform well from a pitch and roll perspective even without the Air Suspension. With it you potentially could have a world class ride.
  3. jcstp
    jcstp Active Member
    Belgium
    I think it must resemble the pneumatic suspension Citroen uses!
    Damping gets firmer in corners and flat surfaces, and gets softer on bad surfaces and slow speed!
    Range-Rover uses same system to get their vehicles corner like sportscars (hard suspension) on asphalt and soft on straits and bad surfaces! Also used to increase rideheight in extreme situations!
    Can also be used to heighten or lower the car for easyer acces!
  4. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Citroen uses hydraulic (oil) pump and nitrogen. Most other high end cars use only air pump. The results are similar, unless you are Citroen.
    Air suspension - Wikipedia, the free encyclopedia
  5. roblab
    Citroen uses hydraulic pump (oil) which compresses nitrogen. Most high end cars using "air suspension" use an air pump, with no hydraulic oil involved. Many advantages, used on large trucks and busses even, probably similar in ways, unless you are Citroen.
  6. Tommy
    Tommy Member
    The great OC
    Tesla Model S will be using an air suspension system by Continental according to this article: Latest News : Vehicle Dynamics International
    Company's web site: Continental Automotive -Electronic Air Suspension System
  7. brianman
    brianman Burrito Founder
    @Tommy - Nice find! Thanks for the links.
  8. Tommy
    Tommy Member
    The great OC
  9. WhiteKnight
    Atlanta
    At the risk of touching off another round of complaints, here is a list of other systems that Continental AG can supply to Tesla:
    Adaptive Cruise Control (ACC) - ACC follows the flow of traffic ahead of the vehicle, even if its forward progress is only stop-and-go.
    Blind Spot Detection (BSD) - Blind Spot Detection warns the driver when there are vehicles in the blind spot of the side-view mirror.
    Emergency Brake Assist (EBA) - Emergency Brake Assist detects critical traffic situations and ensures optimum braking.
    Intelligent Headlamp Control (IHC) - Optimal night vision is essential particularly at night when the risk of an accident is twice as great as during the day.
    Lane Departure Warning (LDW) - The Lane Departure Warning (LDW) driver assistance system alerts the driver with acoustical or haptic warnings before his vehicle is about to leave the lane.
    Traffic Sign Recognition (TSR) - Just drive and let the car look out for the current speed limits – it won’t slip out of its mind
    Continental Automotive -Advanced Driver Assistance Systems
  10. drbradfo
    drbradfo Member
    Portland, OR
    I wonder how many of Conti systems will be used... they also have a Autolinq connectivity system.
  11. AnOutsider
    AnOutsider S532 # XS27
    Like I've said before: I hope the model s is upgradable. I'd love to be able to add these things as they make their way into future S versions
  12. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    I for one am NOT getting the Model S because of it not having these things. OK all except the TSR which I did not know about. I want all of the modern safety features on my luxury car and will accept no less.
  13. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    You canceled your reservation (I thought you had one)?
  14. kgb
    kgb Member
    Houston, TX
    I think he is joking. I find it hard to believe that Traffic Sign Recognition is the option that Kevin cannot live without. I got the joke, but a winking emoticon probably would have helped.
  15. kgb
    kgb Member
    Houston, TX
    Wait, I read that as meaning that he was ok with the car lacking the other options except without TSR he didn't want it. But on second read, it looks like he cares about all the options except TSR. That makes a bit more sense. So if that's what he means, then no winky needed - no joke. I guess the joke is on me.
  16. dsm363
    Nevada
    The double negatives are causing my brain to start smoking. I need to go get more coffee:smile:
  17. Kevin Harney
    Herndon, VA
    I order to clarify my post I think that ACC, BSD, EBA, IHC and LDW are must haves in a LUXURY car and TSR would be a nice thing to have that I had not previously known about. And I guess I should have said I am not getting the car because it does not have these things as options.
  18. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    #18 Doug_G, Jan 3, 2012
    Okay the alphabet soup is getting to be a bit much... bears repeating:
    ACC = Adaptive Cruise Control
    BSD = Blind Spot Detection
    EBA = Emergency Brake Assist
    IHC = Intelligent Headlamp Control
    LDW = Lane Departure Warning
    TSR = Traffic Sign Recognition
    ACC - nice to have, will miss it
    BSD - nah, I use Multivex mirrors and turning my head
    EBA - for the driver with sleep disorders
    IHC - sounds nice
    LDW - for the driver with sleep disorders
    TSR - for the driver with no brain... if you're not paying attention, having a machine do it for you really isn't going to help
  19. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    I think it very likely that Tesla will include this full suite in a couple of years. Getting even the "basic" Model S out the door is undoubtedly a heroic effort. Adding on this suite initially would have added to costs and delays, which Tesla simply cannot afford.
    As for me, I have never had any of these options, never had an accident, and am happy not to have six more things to break.
  20. tdelta1000
    tdelta1000 Active Member
    South Florida
    that's a good question. Did anyone notice any good amount of body roll? Let us know.
