FYI, that size system will not totally replace your electric bill... I’ve got a 23kW system already and will be having 3 powerwalls installed next week. Granted I’m on the coast of Texas so I probably have a few more cloudy days and get hotter (which also impacts performance) and my panels are split up about 1/3 east, 1/3 west and slightly less than a third to the south. The highest single day output I’ve had was back in March of right under 140 kWh. So far the last few months it’s been unusually cloud so I’ve not had a totally clear day during any of the “longest” days of the year. I’m sure I’d go a little over 140 kWh but the panels start to get temp limited it seems. If it’s sunny and hot (mid-90’s) the panels are over 170 degrees and I can see the performance flat line below where it would be on a cooler day.
Just something to keep in mind. Depending on how your panels are laid out you might get more or less, but you won’t get anywhere near 200 kWh per day. I know someone with a 27kw system and the max they have ever seen is about 156 kWh. So I hope you aren’t expecting this system to completely replace your power bill.
Also for us, luckily we have dollar or dollar net metering and no time of use pricing, but the 3 powerwalls would get us completely off the grid in the winter but 3 are about 20 kWh too small to carry us through the night in the summer. We use around 100 kWh total per day during the summer. Hope that helps.
