I have about 15KW of Solar and 3 Power Walls and have been on the old E-6 plan. PG&E is eliminating E-6 and wants me to choose a new plan and says they will select E-TOU-C if I do nothing. When I look at the E-TOU-E versus E-TOU-D, its not obvious with a model which is better.
Summer time and rates for E-TOU-C are 4-9PM peak with below baseline 40 cents per KWHr and above 49 cents with off peak 43 cents and 34 cents respectively.
Summer time and rates for E-TOU-D are 5-8PM peak with no baseline.
It would seem that the amount above baseline I run during summer would be key.
My 3 Power Walls can shift much of my solar power into the 4-9PM or 5-8PM but the TOU-C gain is 6 cents per KWHr and TOU-D is13 cents. At a glance, the 13 cents appears better. But I know PG&E chose these numbers for a reason.
My usage is quite high. Has anyone modeled or done an analysis as to which is better. I don't even know my baseline.
thoughts. Thanks
thoughts. Thanks
