Not sure what you mean by appear here, either it does, or it doesn't. There is a setting to turn that feature on and off. It is a per profile setting, and it likely sets the driver's seat based on which fob unlocked the vehicle. If you aren't using a fob to unlock, then it might not do it. If you use easy entry, that also might change the behavior.
mznym,
OK, I just checked the behaviors of my MX (2018 with latest SW). Here is what it is/isn't doing.
1) We have two fobs - mine and my wife's.
2) The top of the display shows the "current driver" (me or my wife).
3) I have Easy Entry checked. But the seats do not change position to accomodate Easy Entry.
Turning Easy Entry on and off does not change the behavior.
4) I am not 'actively using the fob' to unlock (don't even know how). We just walk up to the
car, the lights come on, and we get in.
5) The current driver does not change on its own based upon which fob is used.
6) We can change the driver by using the center panel - but it does not change on its own
based upon which fob is approaching the vehicle. Yes, this was tested with only one fob
anywhere near the vehicle. By that I mean that vehicle has beeped for "locked". I have
not tested anywhere other than in my garage or driveway (and don't think I should have
to test when "not at home".
7) This 2018 MX-100D was purchased, used from a Tesla dealer, in July of this year. It is
running the latest software/firmware - at least when I go to "update" it says "nothing
to do (you are at the latest level).
8) These behaviors with respect to driver customization and Easy Entry have not changed
since we took delivery of the vehicle in July (yes, there was at least one update since
then).
I think -neither- the current driver nor the Easy Entry are working as expected. Do I have
the wrong expectation or is my car not behaving as expected? If the car isn't behaving
correctly is this the kind of thing that I should just schedule a service call for?
- Jim in the PNW
