I'm going to throw an analogy in. I've done some competitive combat shooting, in and out of the military. When you first start out, the key is to be so experienced, intimate, if you will, with the weapons you utilize. There is a learning curve that requires an exceptional amount of attention to detail, safety and functionality. That takes time: running through drills, dry runs, steady hold factors, sight adjustment/alignment, maximum effective range, bullet drop, and live fire and THIS is just in understanding the weapons capabilities and idiocyncrasies, we're not even close to run and gun...yet. Once mastery of the weapon is accomplished: sighting, immediate action in malfunctions, ammunition capabiliity, carry, breakdown, maintenance, assembly, hold factors, recoil, loading, reloading, etc. etc.(Repetitive, right?), THEN moving into firing scenarios or "run and gun".
In combat shooting, you're beginning an entirely new process which, if not performed with the highest level of safety, you could hurt yourself, others and lastly death could result, unintentionally. Again, there is a learning curve on moving, shooting, carry, ammunition, reloading and most paramount, safety. All this, while competing for time against your opponents. This all takes time. Some more than others BUT, you do not master either without time invested....a LOT of time and practice!
Now, small arms are not autonomous.....yet but, in the context of this thread, experience, mastery, ever vigilance and, above all, safety are key to confidence in my example. Adjusting to stationary, pop-up and moving targets, at different distances, height and size, all requiring a differing skill set. Lastly, after running a day of shoot houses or lanes, I'm exhausted. No so much physically, as I am mentally. You know your weapon, it's parts, what makes it work and how do use it efficiently and effectively (muscle memory) as if you could do it blindfolded. (That'll never happen!) So in comparison, the AP/FSD, new to most of us, requires more than using it only on empty streets or highways but, in every possible scenario to understand the advantages and limitations in any given situation. YET, one should always be prepared for the "unexpected".
