laservet Member Mar 9, 2020 784 671 Williamsburg, Virginia Feb 26, 2021 #1 Feb 26, 2021 #1 Question for those familiar with PPF. I use The Last Coat v2 on the car, should I refresh it before applying the PPF or should I remove it?
2 2101Guy Breaker of Ignore Buttons Jan 6, 2020 4,972 7,664 USA Feb 26, 2021 #2 Feb 26, 2021 #2 remove. You want the PPF to have good adhesion. Best way for that is a clean, contaminant/wax/sealant/coating free, surface.
laservet Member Mar 9, 2020 784 671 Williamsburg, Virginia Feb 27, 2021 #3 Feb 27, 2021 #3 Thank you. What is the best product to use to remove everything from the surface without damaging the paint?
2 2101Guy Breaker of Ignore Buttons Jan 6, 2020 4,972 7,664 USA Feb 27, 2021 #4 Feb 27, 2021 #4 laservet said: Thank you. What is the best product to use to remove everything from the surface without damaging the paint? Click to expand... IPA aka Isopropyl Rubbing Alcohol. Rub on with a clean cloth and let it evaporate. Reactions: MikeBur
laservet Member Mar 9, 2020 784 671 Williamsburg, Virginia Feb 27, 2021 #5 Feb 27, 2021 #5 2101Guy said: IPA aka Isopropyl Rubbing Alcohol. Rub on with a clean cloth and let it evaporate. Click to expand... Thanks, I have a gallon of 99% IPA.
LionelHutz Member Jan 12, 2019 317 405 CA Mar 1, 2021 #6 Mar 1, 2021 #6 laservet said: Thanks, I have a gallon of 99% IPA. Click to expand... Dilute to no more than 20% IPA before spraying on the car. 99% IPA is a strong solvent and not great for your paint or plastic trim.
laservet Member Mar 9, 2020 784 671 Williamsburg, Virginia Mar 1, 2021 #7 Mar 1, 2021 #7 LionelHutz said: Dilute to no more than 20% IPA before spraying on the car. 99% IPA is a strong solvent and not great for your paint or plastic trim. Click to expand... Thanks, will do. I would have used the 99% had I not known.
