Barkeeper's Friend v. WD-40 v. Hydrogen Peroxide
ProtectaClearProtectaClear® by Everbrite Coatings Restore & Protect Your Tesla Cybertruck from Corrosionhttps://www.cybertruckownersclub.co...steel-factory-finish.12002/page-2#post-239808
ProtectaClearEverbrite Coating paint (via ProtectaClear)Everbrite Restores & Protects Metal from Tarnish, Rust & FadingFAQ thread:https://www.cybertruckownersclub.com/forum/threads/protectaclear-cybertruck-faqs-here.12126/
Sheila ShineStainless Steel Polish & Cleaner | Protects Appliances from Fingerprints and Grease Marks | Residue & Streak Freehttps://www.amazon.com/Sheila-Shine-Stainless-Cleaner-Polish/dp/B002XK0KNC
CitriSurf® 77 Pluscleaning, rust removal, & passivation of SSCitriSurf® 77 Plus | Stellar Solutions - Stainless Steel PassivationVia Wes Tesla
Blue Sotch Briteblue non-scratch Scotch Brite pad "
Via Wes -- Cybertruck Lead Engineer plus Reliability, Test, and Analysis for all Tesla vehicles.
_ Stainless is reactive and free iron that sits on it will rust. It's surface contamination only and can be cleaned off easily. Bar Keeper's Friend used here works well, citrisurf77 can also loosen the deposit and simply wipe it off. If anything stubborn use a blue non-scratch Scotch Brite pad as it won't leave any marks on the metal.
_ Iron becomes iron oxide until there's no free iron left to convert. In the process it creates red corrosion product which you'll see on the surface. Clean it anytime or don't if it doesn't bother you. It's not the base metal. The specs are about the size of the pin of a pinhead.
Bar Keeper's Friend powder or liquid?
