Battery Life and Charging rate
Discussion in 'Roadster: Technical' started by dhrivnak, Nov 27, 2011.
  1. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    #1 dhrivnak, Nov 27, 2011
    I tried a little experiment and charged the last two times with my 120V UMC and to my surprise the my ideal miles were up a little from 179 miles to 183. So does anyone know is it better for the batteries to charge them slow? Or is is just a quirk of the software that shows slightly higher numbers after slow charging? Even before the little experiment I have been very pleased to see my ideal miles slowly increase over the past 6 months. I purchased the car used, and have kept a close eye on the battery. Normally I charge at 240V and 30 amp. Tesla_Range.JPG I now have about 7000 miles on the car.
    I also plotted my standard miles and as you can see that number is highly variable depending upon how I have driven the day before.
  2. tomsax
    tomsax Member
    Sammamish, WA
    It's pretty common to get more ideal miles when charging at lower rates. I don't think it's really any nicer to the battery, it's probably just easier for the car to hit maximum capacity on the battery pack at the lower rate.
    RichKae is doing a Roadster battery longevity study to shed some light on this and other issues. If you're curious, consider participating in the study. I'll be releasing a new version of the log parser later today, and will post in that thread when it's available.
