best replacement tires for for 2022 model x plaid for stock 20 inch rims
what are best replacement tires for for 2022 model x plaid for stock 20 inch rims? Also almost every model x with the 20 inch rims comes with a 265/45/20 on the front. Ever the current 2023 model x plaid comes with the 265/45/20 contenental all seasons. But since i have a 2022 plaid which was the only year and only model x that came with 255/45/20 on the front Michelin summer tires
what tires should i go with??? so i change to all season since i assume all season will last longer and even the 2023 plaid comes with all season now. should i switch to the wider 265/45/20?
That was a little hard to read/understand. I think the manuals give all the options for your given year. What does your manual for your *year* say is your options?
AFAIK, the rim width are different (9 vs 10) on the front vs rear which is why you can't rotate them.
See manual section.
Wheels and Tires
Wheel Specifications (Factory)
Tire Specifications (Factory)
Aside: Interesting article: Best Tires for Tesla Model X
