Ben W
Chess Grandmaster (Supervised)
The question I have is what happens on a planet that's a lot bigger, say 2-4 times our mass? I don't know if even nuclear rockets would work.
The NASA article specifies a planet that is 50% larger diameter, which works out to about 3.375x the mass, assuming the same density. So chemical rockets would still barely work. With multi-stage rockets, you could probably escape a planet 4-5x our mass, though the payload fraction would be tiny, less than 1%. Beyond that, you'd certainly need nuclear or some other approach.
