Andyw2100
Securing the door would require installing a new base plate portion of the lock hasp itself. At that point, the person doing such a repair would probably incur some level of liability should there be a subsequent issue with the unauthorized repair.
Sorry. I could not tell from the original pictures that a lock alone would not be enough. (I expect I should have been able to.)
To remove the temptation to enter, perhaps someone could close the door and place a rock in front to prevent the wind from blowing it open again. I don't think putting a lock on it is worth the effort. If someone wants to get in it appears fairly easy to scale the walls.
A rock, wire tie, etc seem like better options to me.
I'm sure you two are correct. Something simple that just makes it less obvious that the enclosure is not secure would go a long way towards making it less likely that something bad happens.
