East Rochester has that defunct Acura dealership building. Nice size, could probably be had for a song. less than a mile from Pittsford, and Brighton (which may have more Teslas...)
Then you may be familiar with the building? Beem vacant for a few years now:
Google Maps
Any ideas on how to promote this idea?
I tried to use the SC today around 3:40PM and noted some sort of accident on Transit Road just south of the stoplight controlled entrance to the Eastern Hills Mall. The stoplight in question was out. I turned into the mall to bypass the road blockage and made my way to the SC where I noted the illuminated, "Tesla" was dark as was the Key Bank sign. Hopefully the SC will be up when the local power is rstored. And yes, I did try to charge.
Wind damage? Seems unlikely that someone would break in and then not take advantage...Visited the SC today and found the front gate of the enclosure open, the lock on the ground apparently broken off from the baseplate. I called Tesla to notify them of the situation and was told they would send someone from their SC team. The SC was fully functional.
View attachment 101772View attachment 101769View attachment 101770View attachment 101771
Gate is still wide open as of Wed. PM.
Cabinets are locked and should not be accessible to cause a dangerous situation. Issue is more around damage to the equipment itself but vandals.
The incident you are referencing happened to an electrician presumably with access to inside of cabinets. Let's not create an issue that doesn't exist.
To remove the temptation to enter, perhaps someone could close the door and place a rock in front to prevent the wind from blowing it open again. I don't think putting a lock on it is worth the effort. If someone wants to get in it appears fairly easy to scale the walls.
