I saw this report but I can't find any additional source to verify the recalls:
Ford Mustang Mach-E: Bad News for Drivers… and Criminals
Apparently two recalls
First, on 3,178 units, the windshield may not be properly attached and could separate from the vehicle in a crash, significantly increasing the risk of injuries for occupants. Dealers will have to remove and reinstall the windshield using the correct method, something that wasn’t done at the assembly plant for some reason.
The second recall involves 1,812 Mach-Es. Here, it’s the glass panel of the panoramic sunroof that may not be properly attached and could separate from the vehicle over time. Dealers will clean and install additional adhesive to the panoramic roof glass.
I'm sure if these are valid reports, since I can't find anything to validate these reports...
