So, consider the equipment from Lectron noted above, purportedly designed to tell the car that 16A is OK on a NEMA5-15. Nobody's saying that the Lectron hardware itself is going to fail; I imagine that the wires, metallic contacts, and all that jazz is just fine at that level.I have the Lectron Tesla "extension cord": the one that has NACS plugs, male on one end and female on the other end and extends the Tesla NACS plug. I have used it a couple of times when charging from a dryer outlet (not at home) using the Tesla Mobile Connector. The cable is thick and heavy, much thicker than the cable on the Tesla Wall Connector and Mobile Connector.....does not seem cheaply made.
It's the surrounding hardware in the wall that's at danger. The fact that, say, the Lectron doesn't burst into flames doesn't help the poor homeowner who suffered an in-the-wall smoke & fire because the cable the electrician put into place wasn't designed to handle 15A continuous, never mind 16A continuous on a 90F day when surrounded by building insulation.
Come the day Lectron gets found out, presumably after some Fire Department investigator after the fact figures it all out, how likely does anybody think that Lectron could get successfully sued? What if there's dead people as a result? Think any of those idiots will have to answer for their error on safety-related specs?
