I am selling a working Gen1 Mobile Connector with NEMA 5-15 and 14-50 adapters. $200 firm.
The max amp is 40, so will allow you to charge a little faster than the Gen2 with swappable adapters. It is capable of 9.6kwh @ 240V.
You will want to make sure you have a harness/bracket to secure the charger against the wall — if you are planning to use the NEMA 14-50. This older design obviously puts the weight further out from the plug outlet and gravity will cause the plug to slip out ‘ever-so-slightly’. Better safe than sorry… so use a bracket if you can.
Note: the button does not open the charge port. I have another set I am actually still using that also exhibits the same ‘issue’, so my only guess is the transmitter weakens or stops working over time.
