Car for Storage
Discussion in 'Model 3' started by jednav, Mar 2, 2021 at 7:02 PM.
  1. jednav
    jednav Member
    surrey bc
    I am planning an extended vacation for at least 3 months and intend to place car in storage.
    Anyone knows what the book says on what to do in this kind of scenario?
    Thanks
  2. justsomeguy
    justsomeguy Member
    Vancouver, Bc
    Set charge limit to 50% and plug it in, should be fine.
    If you can't leave it plugged in, charge it to 90% and turn off everything, probably including mobile access.
  3. jjrandorin
    jjrandorin Moderator, Model 3, Tesla Energy Forums
    Riverside Co. CA
    If by "book" you mean the tesla manual, yes there is information specifically about that in the manual:
    Page 153 of the manual that you can find online
    https://www.tesla.com/sites/default/files/model_3_owners_manual_north_america_en.pdf
    About the Battery Model 3 has one of the most sophisticated battery systems in the world. The most important way to preserve the Battery is to LEAVE YOUR VEHICLE PLUGGED IN when you are not using it. This is particularly important if you are not planning to drive Model 3 for several weeks. When plugged in, Model 3 wakes up when needed to automatically maintain a charge level that maximizes the lifetime of the Battery.
  4. jednav
    jednav Member
    surrey bc
  5. jeremymc7
    jeremymc7 Active Member
    U.S.
    What are your specific storage plan?
    Ideally it would be best to not let it sit on the tires in the same spot for months without being driven or even trickle charged?
    Where are you storing, how much do you want to spend, who will have access, what are you’re limitations.
    IE something like a Carcoon, plugged in or at East using a trickle charger on the 12V, and put it up on jacks / blocks with pucks.
  6. jednav
    jednav Member
    surrey bc
    Modertor you answered my last post. thanks
  7. justsomeguy
    justsomeguy Member
    Vancouver, Bc
    Yes, but not immediately. I think there is some buffer like 1-3% before it will top off the charge.
  8. jednav
    jednav Member
    surrey bc
    [QUOTE="jeremymc7, post: 5370085, member: 12222"
    IE something like a Carcoon, plugged in or at East using a trickle charger on the 12V, and put it up on jacks / blocks with pucks.[/QUOTE]
    Sorry what is a carcoon? trickle charger for what?
  9. jeremymc7
    U.S.
    Carcoon
    Carcoon Automotive - Storage Systems
    There are many other similar. Varying qualities and prices.
    If you keep the car plugged in with it’s not normal charger as others mentioned that good. Some people use trickle chargers on the 12v battery. But it’s largely a carryover from ICE cars.
    There’s been back and forth discussion of trickle charging the 12V battery separate due to stresses of storage for months. Some say just use the app to force awake the car plugged into the charger while gone. Others state you need to put pop the hood and connect a trickle charger to the 12V. You might want to search the forum or start a separate thread. Or just check Google.
    https://www.google.com/search?safe=off&client=safari&hl=en-us&ei=oBs_YLOyK8Tf-gTr8afoAw&q=trickle+charge+tesla+12v&oq=trickle+charge+tesla+12v&gs_lcp=ChNtb2JpbGUtZ3dzLXdpei1zZXJwEAMyAggAMgUIABCGAzIFCAAQhgMyBQghEKsCMgUIIRCrAjoECAAQRzoFCCEQoAE6BAgAEEM6BggAEBYQHlCUzgJYpY0DYKOPA2gGcAF4AIAByQGIAd8OkgEFOC43LjGYAQCgAQHIAQjAAQE&sclient=mobile-gws-wiz-serp
