The rate of charging is not linear so it is not easier to make a direct conversion between time and cost.
Basically if you added 24 kWh in your battery, it would cost you $7.20 (at $0.30 / kWh), and
- if the average charging speed is 24 kWh it will you take you 60 minutes and you will have spent $7.20 (for a $0.12 connection rate by minute), or
- if the average charging speed is 48 kWh it will you take you 30 minutes and you will have spent $7.20 (for a $0.24 rconnection ate by minute).
So if the average rate of charging is faster that 24 kWh (for low rate) or 48 kWh (for high rate) your are a winner !!!
An other way to look at is to use an hypothetical charging rate:
- For 6 minutes, if the charging rate is 100 kWh, this will add 10 kWh and it would cost you $3.00 (at $.30 / kWh) or $0.72 (at $.12 / mn) or $1.44 (at $.24 / mn)
- For next 6 mn, if the charging rate is _75 kWh, this will add 7.5 kWh and it would cost you $2.25 (at $.30 / kwh) or $0.72 (at $.12 / mn) or $1.44 (at $.24 / mn)
So after 12 mn, this will add 17.5 kWh and it would cost you $5.25 (at $.30 / kWh) or $1.44 (at $.12 / mn) or $2.88 (at $.24 / mn)
- For next 6 mn, if the charging rate is 50 kWh, this will add 5 kWh and it would cost you $1.50 (at $.30 / kwh) or $0.72 (at $.12 / mn) or $1.44 (at $.24 / mn)
So after 18 mn, this will add 22.5 kWh (avareage speed 75 kWh) and it would cost you $6.75 (at $.30 / kWh) or $2.16 (at $.12 / mn) or $4.32 (at $.24 / mn)
Note: I might be wrong in my quick calculation, correct me if needed...
