Charging Port Placement
Discussion in 'Model S: Ordering, Production, Delivery' started by DermMD, Aug 9, 2018.
  1. DermMD
    DermMD Member
    Columbia. MD
    I wonder whether Tesla can customize a model S to place the charging port on the passenger side. Theoretically not hard but has anyone asked? Perfect for 2 cars sharing a charging port in a garage.
    • Funny x 4
  2. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Sure they may be able to. But I'm pretty sure that no, they won't do it for a single car.
    There is a problem with it, since Superchargers expect it on the left. If it was on the right, you would park in the wrong place
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Simple* solution: charging ports on both sides of the car.
    * No
  4. jeffro01
    jeffro01 Active Member
    SF Bay Area
    I've often wondered why they didn't do that... My guess is cost plus end user confusion...
    Jeff
  5. P85_DA
    P85_DA Supporting Member
    Was this supposed to be a serious post ? Unless someones EVSE cable was two feet long why would this be needed ? Most cables can stretch across a two car garage easily
  6. trm2
    trm2 Member
    CLE
    My outlet is in front of the car and the cord is just barely long enough to reach my car, it would not be anywhere near long enough to charge a car sitting next to me with the current setup. Put a charge port on the passenger side and yeah, I turn around and plug in.
  7. P85_DA
    Makes sense I have a 24’ WC that thing can stretch over under sideways and still has slack ;) ...yes the UMCs have shorter cords ...there are companies though that can modify cord length on the UMC that may be option link below
    J1772 Adapter | Home
  8. ItsNotAboutTheMoney
    Maine
    Well, it can stretch, but depending on layout (and clutter) of the parking area it can be a lot easier if you don't have to walk around the car.
  9. Lasairfion
    Lasairfion Member
    UK
    #9 Lasairfion, Aug 10, 2018
    Most UK cars have fuel filler caps on the right so I was wondering if Model 3 Right-Hand Drive vehicles might have charge ports on the right in which case then there would be car bodies with the option for right hand side charging ports.
    However, thinking on it, the Model S and X RHD cars charge on the left side, so the superchargers will be set up for that; meaning that this isn't going to happen with the Model 3 as they wouldn't fit in the current charge bays.
    On the up-side, having charge ports on the left does make on-street chargers easier for us here as the cars will be parked facing the correct way with the charge port on the pavement-side, rather than the road-side.
