Thanks David. If you can contact the owner I do have a few specific questions I'd like to ask.
I was able to locate the owner, and have reached out to him to learn a little bit more info on the car, but have not heard back yet. Hopefully I will hear back.
I've repaired about 7 salvage Teslas in Ukraine. (My main home is in LA area, but have 2nd home in Ukraine.)
Rear drive unit and components are obviously fine.
Main concern is the viability of the battery pack. This is certainly a risk, which I am completely aware of. I bought it based on carefully studying many factors, including watching that video about 100 times, looking very carefully at the damage/burn pattern and area, and I found some additional photos of the car.
I've torn down and reassembled several battery packs. To be honest, I think 90% chance the pack will work perfectly. 5% chance the front 2 modules and possibly cooling tubes in front of the pack will need to be replaced, as the front of the pack suffered the greatest exposure to heat.
I analyzed:
1. Exactly where the fire was burning vis a vis the pack - most of it was burning ABOVE the pack location
2. How long it was burning before put out
3. Ambient temperature at the home address before and during when fire occurred (important because ambient temp of pack was very cold - heat from the fire likely didn't raise cell temp too much - like taking a turkey that's frozen solid out of the freezer and hitting it with a blowtorch for 5min).
4. How much water was sprayed on the pack (pack could've survived the heat, then be destroyed by water from firefighters)
5. Aluminum melting temp vs steel melting temp (600C / 1500C)
6. Fact that aluminum bar that supports the 12v battery is still intact is a good sign
And a bunch of other stuff.
I already have a P90DL MS, and P90DL MX, the plan for this car is its vitals (rear motor/battery) will be transplanted into a very clean 2017 MS 75D I have in Ukraine, and we will convert that car to a P100DL. Hopefully! )
I'll let everybody know how it turns out. If that pack does work properly out of the box, it will be an amazing testament to the great structure and insulation of this battery pack design.
