Contactor Damping to Eliminate Noise
Discussion in 'Technical' started by kennybobby, Dec 31, 2015.
Tags:
  1. kennybobby
    kennybobby Member
    Heart o' Dixie
    TM has a patent application that discusses adding damping to stop the oscillation and squeal noise that can occur during the passage of large DC currents thru contactors. It was thought to be motion of the movable contact relative to the stationary contacts causing the noise. A time history of voltage drop across the stationary contacts shows an audible resonance frequency of ~1.5 kHz:
    Several damping solutions were proposed including rubber 0-rings and metal spring friction dampers at the outer edge of the movable contact:
