Not sure if these are exclusive to v9, or even the model 3, but I found 2 pretty fun things out this morning on the 3:
If you are like me, you are annoyed that there isn't a way to run 'fan only' in the model 3 and avoid heat from coming on when you want to maximize range (This is kind of ingrained in me from having 2 volts with only 10 kwh useable and then 14 kwh on my gen 2 volt...I would run in fan only most days just to keep the window defogged....). There isn't an easy way to do this in the 3 other than dropping the temp to ~ 17C and keeping the fan mode off recirculate. The problem is that when I do want some heat I would have to 'click' the touchscreen a bunch of times to get it up to ~ 20-21C, but then after a few minutes I would want to drop it back down to ~ 17C.....so lots of clicking/interaction with the screen which I didn't like.
Well, this morning I discovered that the temp control can be used as a slider bar to make large changes in temp virtually instantly. Ie, if you press on the temp and just slide your finger horizontally you can go through the whole range of temps in an instant. Maybe other people know this, but I was happy to find it
Other 'tip' is that this same 'feature' works from the music icon to 'drag' the music player tab through its 3 screen sizes: 1 row, medium and full screen. I thought that was pretty useful too and worth sharing.
Happy tuesday
Happy tuesday
