Customize number of panels?
I tried searching with no luck. Will tesla install extra panels? The 8 kW system is just barely covering my usage. I think a 9-10 kW system would be perfect for me. 12 kW is overkill. (Plan on getting 2 powerwalls to if that makes any difference)
thanks!
Unless there has been a change in policy, you should be able to customize the number of panels after placing an order with a standard size selected - you should be able to let your advisor know you want a new design with more/fewer panels as soon as one is assigned to you.
Reactions: jjrandorin
