Gerasimental
IMO you have to wait for the next Roadster in 2019.
or get an SP:01 to tide you over!
Not necessary, transmission will always improve performance of any given motor, be it under sized, over sized or right sized.If it needs more than a two speed transmission it likely means the motor is under sized.
...transmission will always improve performance of any given motor, be it under sized, over sized or right sized...
Performance is a broader term then 6-60 acceleration.
Transmission simply gives you ability to output max available power at much wider speed interval. Usually from some min speed up to max speed.
With single gear ratio, maximum power is not available above some speed.
Of course, if your battery is 3 times stronger than motor, than above does not apply. Little logic applies to such strangely imbalanced systems.
This evidence proves my point ... a tesla with multigear transmission would have much better high speed (above 80mph) acceleration.(Evidence: Tesla)
It certainly would. But I would prefer that Tesla not spend any resources towards developing multi-speed transmissions at this time because the increased sales that would result would be minimal. For the vast majority of prospective buyers a single-speed transmission is all they need. Obviously some additional sales might result if a multi-speed transmission was available, but since Tesla remains production constrained for the foreseeable future I see no compelling reason to invest engineering resources in an option that only a small number of buyers would choose to pay for.This evidence proves my point ... a tesla with multigear transmission would have much better high speed (above 80mph) acceleration.
....two speed is optimal.
We don't know if that is the case or not. Don't assume it to be so.Aren't the D models in essence two speed already, by having different torque curves for front and rear drive unit?
We are in agreement, no reason to introduce a 2 speed tranny. What I was saying even if both DU have 9.73:1, because the front motor is smaller f and r may have different torque curves, and voila!, it becomes a two speed car! Not from a mechanical standpoint but from torque as function of speed standpoint.We don't know if that is the case or not. Don't assume it to be so.
I don't expect Tesla to move away from a single speed gearbox any time soon. There is no compelling reason for them to do so as it would only fractionally increase their addressable market and since Tesla is still production constrained it would not increase their sales.
I'd thought about this too, and it seems like the obvious thing to do, but wouldn't it be very clear from the car's performance (much better at high speeds, much worse at low speeds) if this were the case? I think it's possible they didn't do this and sacrificed high speed performance for good 0-60 times.
