After getting the PowerWalls/solar panels installed, you should run an "off-grid" test, simulating loss of grid power and verifying the new system properly transitions to off-grid mode, and turns off/on the solar panels (based on PowerWall charge level) and then returns to grid mode.
During this test, it's easy to find out which devices inside the house are impacted by the switch from grid to local power - and then add UPS for those devices, if you don't want them to reboot when grid power is lost.
These UPS boxes should only be needed to provide power for a few seconds while the TEG takes control, sets the powerline frequency and uses power from the PowerWalls and solar panels for house power.
This means you may not need to invest large UPS boxes - since they will only be needed for a few seconds...
Note that some UPS boxes may not work correctly if the power isn't at 60Hz - we have one of our UPS boxes that we pulled from use because it refused to work when the TEG set the frequency above 60Hz.
