wwu123
Got it, makes sense to me - my vote is a heat pump water heater, used on your spa loop as opposed to your potable water supply, with the 2-3X efficiency (i.e. additional heat). You could even set it hotter than you would an electric tank heater, the additional efficiency more than offset the standby losses of a higher set temp. It's merely an air-to-water heat exchange loop, just with a compressor cycle...I currently have a solar hot water setup. (Should never have done it since the in winter, at best, it only gets to 75 degrees)
I have one exchange loop in the tank solar that goes to the spa. Does nothing worth while in the winter. And it does take way too long
unless the tank is at like 150 degrees like it is in the summer.
So, I only think about fast heat when I change the water and want to use that night.
Otherwise, a slow, constant heat with an exchange loop is fine. It is a nice small pump running.
So, if I added another tank, with loop, and it can be heater like a water heater, it just gives me another option
to heat the spa in the winter I would be hoping via the two exchange loops in series. If the solar is colder, I guess the
water going it might even back heat that tank.
Bonus points if your spa is situated that you could run a passive gravity loop, and not even need a small pump, gravity would constant replenish the cooling water from the spa with hotter water from the tank...
