Experiencing Suspension Issues and Air Spring Leak Error - Seeking Advice
Hi Tesla community,
I hope you can help shed some light on an issue I've been experiencing with my Tesla. First off, let me clarify that I'm genuinely seeking understanding and assistance, so please refrain from telling me I shouldn't be asking here.
Recently, I've noticed a slight rocking motion in my vehicle when driving at low speeds, around 20-30 miles per hour, on a smooth road. Concerned about this, I accessed the Service menu and found two error messages:
  1. TAS_a240_airSpringLeak
  2. TAS_a290_twistSustainedAtSpeed
I reached out to the service center, and after a diagnostic check, they informed me of the following:
"Diagnose customer concern, air suspension alert on dash, technician confirmed it was the bracket causing the alert, replaced ride height sensor."
The following components were replaced:
  1. Bracket - Ride Height Sensor - Rear - LH (Remove & Replace)
  2. AIR SUSPENSION RIDE 1.00 HEIGHT SENSOR
  3. BRACKET - REAR LEFT HAND(6006523-00-B)
After these replacements, they assured me that all errors were resolved and the air leak issue was likely due to the sensor's improper functioning. However, on my way home from the service center, I once again noticed the rocking sensation at low speeds. Frustratingly, when I accessed the service menu again, I found the same air spring leak error message.
Additionally, while exploring the service menu, I came across an image, which I have attached at the end of this post.
Second picture - before service. First and third- after service.
I'm curious if anyone can explain its significance and whether I should pay attention to it.
I would greatly appreciate any insights, advice, or similar experiences from fellow Tesla owners or anyone knowledgeable about these issues. Thank you in advance for your help!
I'd get the soapy water test on the go with the front air springs asap.
If one is leaking the compressor is working harder for longer and getting hot very often. This will lead to it also failing not long after the strut is replaced.
I know this from experience.
Reactions: abalexab
