A few months ago I tweeted Elon suggesting that the first FH payload be a Model 3 release candidate car, since it is going to be crushed anyway. Burning it up on re-entry would be more dramatic.I would die laughing if they launched a Tesla
Surprisingly, he did not tweet me back...
Practically speaking, the payload has to be (a) balanced and (b) strong and supported rigidly enough that it will not fall apart due to launch vibration and forces.
A great article on SpaceX, LC-39A, SLC-40, and some info on FH being worked on:
SpaceX Falcon 9 conducts static fire as Falcon Heavy waits in the wings | NASASpaceFlight.com
Hi @Grendal. Has SpaceX made public any changes to the F9 Static Firing Test procedure for Falcon Heavy?
If they plan to do a full 27 engine test, I would imagine they would need additional hold down hardware on the pad for each of the side cores. Putting triple the load on the existing ones, not to mention the attach points on the center core, would seem (to a non engineer like me) to be a bit imprudent. Any info or thoughts?
I have been reticent to ask what may be a stupid question. At some point in the future when reusability levels have been well established, might test burns be at least partly eliminated? They seem quite wasteful, should there not be a better way to establish readiness?So far, each side booster and core have been test fired individually at the McGregor testing facility. ..
I understand. My question is that sooner or later they'd seem to want to minimize foreign stresses induced by testing.I'm not an expert by any stretch but my understanding of the stresses experienced during launch and re-entry mean that they almost have to rebuild the engines. The refurbished engines have to be re-certified. Any fuel 'wasted' is a rounding error compared to a $50M+ payload...
As a tiny difference, few commercial aircraft use full thrust for takeoff. Much lower thrust is ordinarily used so that directional control can be maintained in the even of an engine failure. After takeoff thrust is then added for climbing, then generally reduced somewhat for cruise. There are exceptions. The most striking such cases are with two engine aircraft with the engines mounted on the main wing.If you use commercial aviation as an example they go to full thrust to take off but they have a few seconds to abort the take off if something is wrong with the engines. Is there a similar opportunity with a rocket? That would be interesting to know. I don't think I've ever seen an abort after ignition. That might be one reason they would always have a static fire test...
From the way SpaceX is talking about reuse, the engine hours spent test firing aren't a big concern. The first recovered stage was test fired 8 or 9 times in a row for full mission burns without significant rebuilding as I recall.
That brings back a painful memory. Luckily the takeoff happened, the flight was uneventful and I was the only one who ever knew how nearly terminally stupid I had been was me, and now you.... A short field departure, hot, high and heavy, that's where the stress part comes in.
Robin
