Hey guys,
We’ve got a minor problem with our 09/2020 MYP with 24k miles.
The left rear door open/closed sensor in the door latch appears to be malfunctioning. When you open the door the window rolls down like you’d expect but if you release the handle after you clear the door trim the window rolls back up to fully closed. If you pull on the handle again the window lowers back down. Also the door open animation does not change, it always shows to be closed.
Probably a simple part swap, something that hopefully, mobile service will be able to take care of.
Has this happened to anyone else?
