I've actually had my solar for almost two months, but it was turned on a few days into my electric utility billing cycle. So I've just gotten the bills for my first fill billing cycle with solar. This is for a 30-day cycle.
I use a little over one MWh per month. I pulled 20 kWh from the grid. I pay the $25 minimum plus $1.17 "green infrastructure fee." Apparently the solar+Powerwall system cannot react to changing demand fast enough to be completely independent of the grid. So if I wanted to disconnect completely, the cost of the system would not be worth it. Plus I have the grid as a backup if my system goes down for some reason.
The renter in the cottage uses about 570 kWh per month. Because she is at work all day and except for daytime A/C uses all her energy at night, she sometimes drains the Powerwall, and this billing cycle she pulled 45 kWh from the grid. So she went over the minimum usage, so the minimum charge does not apply, but the Green Infrastructure Fee still applies. The bill for the cottage is $27.26, or a dollar more than the minimum charge.
Both the house and the cottage can be kept as cool as we like for free since most of the A/C demand comes when the sun is shining. We had a couple of cloudy days when my solar production was down, but the A/C didn't run as much either. I'm still looking into getting soft-start for the A/C compressor so that I'll have A/C when the grid is down. My system has enough power to run it, but cannot supply sufficient amperage to start it. Otherwise I have power when the grid is down.
