ATPMSD
plugged in,
This does not make sense. If the car is plugged in you should not be seeing a mileage loss.
plugged in,
Droschke, my area of expertise is accounting and income taxes, not battery-electric vehicles. My hobby is growing stuff to eat. (Just starting to dig onions!) LOL
From my occasional and empirical knowledge:
Our climate is extremely hot from sometime in May until October. It can be cold (not freezing cold, but California cold) from late November through the vernal equinox. Our garage can stay in the high 80s or more during the hot weather and in the low 40s in the cooler weather. The shoulder periods average between 50-60.
During the more extreme months, I lose a couple percent per day. During the so-called temperate months, the loss is trivial.
I would be curious to see if your environment reflects similar temperature fluctuations, and if the battery responds likewise, before considering where your car falls along some spectrum.
I am not saying you do not have vampire drain as you always do. But with the car plugged in any drain is moot as the car is charged to replace it.You always have some vampire drain whether the car is plugged in or not. But since you disagree, here is a thread with an opposite conclusion, which I'm testing it out starting today to see if it helps:
Cutting vampire drain
After some experimentation I managed to cut my drain (2020 LR) from 2.2KwH to 0.7 KwH per day (measured at the power meter). Seems the biggest contributor to the consumption was leaving it plugged in - unplugging the charge lead meant the car went to sleep without charging intermittently...teslamotorsclub.com
But that's not what is being discussed in this thread or many other threads about the vampire drain, when you lose energy (sometimes by large amounts) when the car is not in motion.
The measurements are taken for 24 hours intervals each; and only when the car is parked in the garage, plugged in, and not driven
While vampire drain still exists, how did you measure it with the car plugged in?
Update:
I have been doing some measurements since I started this thread.
- The measurements are taken for 24 hours intervals each; and only when the car is parked in the garage, plugged in, and not driven
- The average miles loss = 5.1 miles
- The average percentage loss = 2.13%
Is the drain high, low, average?
As I noted above, using the same method I described above, I've now started to take measurements with the car not plugged-in to see if it makes any difference. The first day shows a noticeable difference:
First 24 hours, while not plugged-in:
- The miles loss = 2 miles
- The percentage loss = 0.83%
For a three-week period while plugged-in:
- (max/min loss in miles = 8/4)
- (max/min loss in % = 3.33/1.67)
I’ll keep measuring while not plugged-in for a while to get a better sample for plugged vs. unplugged comparison.
Impressive findings. I’m gonna be doing some studies of my own as well. I agree with your statements on this thread about excessive vampire drain a hidden cost no Tesla owner wants over time. I’ve noticed more vampire drain than I would lIke recently and I am just now starting to look into it. The final straw was yesterday when I charged to 182 miles at around 1pm. My only interactions w the car since that time were showing someone the roof opened and reclosing it. I was shocked this morning when I saw it at 172 miles 20 hours later. It was not plugged in. For the test environment it will remain in the garage. Energy saving mode is on w always connected off. That was already the case but now for the changes I made today. Smart summon turned off, along w cabin overheat the protection off. I’ll have to report back tomorrow at 4:15pm est with loss findings. Garage temp is about 84 and car is never plugged in unless charging.Update:
Vampire drain, car not plugged-in vs. plugged-in.
not plugged-in:
- Values unchanged for each 24-hours window
plugged-in:
The only downside is when the car is left unplugged, my Tesla app does not connect to the car any longer (the connection is almost immediate when plugged-in). The connectivity is via wifi in both cases.
As it relates to my car at least, my conclusion is that my vampire drain is more than twice higher if I leave my car plugged-in vs. unplugged. Weird, but that's what my tests have been showing over the last 4 weeks.
I know for a fact the previous owner had it changed but I’d have to bother them to find out the exact date. Unfortunately Tesla isn’t straightforward with previous owner service records.Hoe old is your 12V battery?
Generally yes, but I can think of situations where a mileage drain will be seen even when plugged in.This does not make sense. If the car is plugged in you should not be seeing a mileage loss.
Likely because the car is in "sleep" and taking time to wake it up when you open the app.The only downside is when the car is left unplugged, my Tesla app does not connect to the car any longer (the connection is almost immediate when plugged-in). The connectivity is via wifi in both cases.
Just to clarify the 182 to 172 drop happened overnight from 1pm to 9am the next morning. Something definitely kept the car awake that night. The car was Not plugged in when the drop occurred. So far it looks like turning summon off along with cabin overheat protection is helping. I also locked the car in garage-2 in 24 hours unplugged is great. Can't go less than that.
You had -10 plugged in.
