BerTx - You mention a good point no one has brought up in this thread yet. Like you say (you obviously know these EVSA products), their 14-50 extension cord does not have a neutral prong or conduit. (has only 3 prongs, not 4). And me thinking that to have it terminate in a 120v adapter for wall plug use might be a problem, I asked them about it.. They say they are fully aware of the issue and "It will work" and they've confirmed on a Model S. See their recent response below. Maybe I just need to see for myself, first manually setting at max of 80% of either 15 or 20 amps, then seeing what the car's system does as I plug in a higher permitted load to see if the Tesla system limits the higher load from coming through... or maybe refuses to charge at all. (Or, just lug around a 2nd extension cord, 10 or 12 gauge, even though I already have a nice heavy 20' of gauge 6 cabling I was hoping to do the trick for both purposes.) -RCWtristan.
Quote:
Hi Bob,
That's right, the Tesla charger does check the polarity and will refuse to charge if wired in reverse. The 120V adapter we sell was designed with this in mind, and we actually tested it with a Tesla Model S to make sure it operates as intended. You can be confident it will work with your Tesla.
Best regards,
John Rowell
EVSE Adapters
On 12/13/2017 04:41 AM,
[email protected] wrote:
John - Here’s some blog-comments on Tesla website from someone else basically discussing same concept: use of the 14-50 cord for two purposes. Seems like Telsa charging ‘brain’ is a bit fussy about some of the connections (see last comment) due to the lack of a neutral conduit on your cables. You know if anyone has used the EVSEadapters120 volt adapter on a Tesla? - Bob
Hi Bob,
That warning is mainly to keep people from buying it for their RVs. Because this cord (the NEMA14-50) is designed for EV charging, we can keep it as small and light as possible by using just 3 wires - two for power and one for ground. RVs require a four wire cord so it won't work for that application.
We actually offer a 120 volt adapter now which you can use with this extension cord - you can find it here:
NEMA 14-50R to 5-15P 120V Adapter, 2 ft.
Regards,
EVSE Adapters
Email:
[email protected]
Body:
...However, I just re-read the spec on the 20' NEMA 14-50 cord you sell. It says the Neutral prong is not present which allows it to be used for other purposes. And thus I am now thinking maybe the heavy cord could not be used as a 110 volt extension cord for regular wall socket slow-charging. The description says the neutral prong is for supplying 120 volt power and thus not needed by elec veh chargers. Is this right? Should I have bought a different NEMA 14-50 cord that would have also served to use as an extension cord for 120 volt slow-charging (with adapter)? - Bob Wenneson
