And in the phone, you just drag it. No setAfter tapping "set charge limit", you have to physically drag the triangular slider at the bottom of the battery icon with your finger. It gets kind of "sticky" at 90% to help you hit that level exactly, so you might need to move the triangle slider back and forth a few times to free it up and slide it all the way right to 100%.
My Mercedes EV has a button called “range charge” which does just that. Every charge is a 90% charge unless you press the button before or during charging, then just that one charge will be a 100% charge. However, it doesn’t allow any other customization of charge beyond that. Although I don’t know if there’s actually any battery benefit to charging below 90%. Is 80% actually better for battery longevity than 90%? I would doubt it but not sure.What would be very helpful - having the 100% setting apply only to the current charging session (or at least have an option to have the charging level returned to 90% after leaving the charger at 100%).
The car would have an alert if the setting is over 90% for a few days.WARNING - after doing your 100% charge, you'll need to manually change the charge level back to 90%, otherwise you'll keep charging to 100% for subsequent charging stops.
80% is supposedly slightly better for battery health. That should be balanced with one's mental health in possibly increasing range anxiety vs one's anxiety about battery longevity.My Mercedes EV has a button called “range charge” which does just that. Every charge is a 90% charge unless you press the button before or during charging, then just that one charge will be a 100% charge. However, it doesn’t allow any other customization of charge beyond that. Although I don’t know if there’s actually any battery benefit to charging below 90%. Is 80% actually better for battery longevity than 90%? I would doubt it but not sure.
