identifying Model 3 trim level using GVWR
I couldn't find such information online. Having gone to the trouble to try to tabulate it, I'm posting it in the hopes that it might help someone else trying to find such information.
The goal was see how practical it would be to use just the GVWR (Gross Vehicle Weight Rating) to identify (or at least narrow down) what trim level a Model 3 has (and possibly what battery, construction technique through use of gigacastings, etc.). For those who don't already know, the GVWR is on the doorjamb sticker.
This may take some iterations to complete the information, and I'd welcome insight into the missing pieces.
NOTE: the production date ranges are approximate and based only on door jam stickers I've seen.
2017kg / 4446lb
trim: "standard plus"
production: 6/2021-10/2021
2060kg / 4541lb
trim: "standard plus" / "standard"
production: 2/2019 - 3/2020
2113kg / 4656lb
production: 8/2021
2126kg / 4687lb
trim: "mid range"
production: 12/2018
2129kg / 4694lb
trim: "" (base Model 3 w/ no extra text)
production: 7/2022-10/2023
battery: LFP?
2137kg / 4711lb
production: 11/2021
2180kg / 4806lb
trim: "long range"
production: 4/2018-11/2018
2207kg / 4866lb
trim: "long range dual motor"
production: 1/11-7/2023
2212kg / 4877lb
trim: "dual motor" performance
production: 4/2022-11/2022
2215kg / 4883lb
production: 12/2021
2220kg / 4894lb
production: 9/2021-10/2021
OR
production: 9/2021-12/2021
2265kg / 4993lb
production: 1/2019-9/2019
OR
trim: "dual motor" (only a subset may be performance)
production: 7/2018-11/2018
2301kg /5072lb
production: 1/2020-9/2020
OR
trim: "dual motor"
production: 9/2019
Reactions: shahryaran
I did the same data breakdown for the Model Y, but that post got flagged for review (presumably because I'm a new user). It didn't help that I accidentally put it under Model X and there doesn't appear to be any way to move or delete the post. :(
Also, things are not going to plan, as I incorrectly assumed that I would be able to just edit and improve the list in the post over time... but this forum is configured with an edit timeout.
Still, I think the data is (mildly) interesting. It was no great secret that there were a lot of design revisions on the Model 3 (thirteen different GVWR that I've counted so far), but even the Model Y has quite a few iterations. Maybe there is some secret corner of the Internet that already tabulates these revisions, but I couldn't find it.
For example, there are at least nine different GVWR for the Model Y in the USA, even though there were only five US models (and four different semi-official curb weights amongst those five).
