It is technically available. It’s just a very, very poor implementation and doesn’t work well.When will the noise cancelling feature be available in model s plaid, if ever?
It works and is quite noticeable. However it often goes out of calibration (which I hear quite clearly even while playing the radio) and it won’t recalibrate until I shut off the radio for a few minutes.
If you just received the car it might not show up until you get the first update. It’s a bit weird for sure. But it absolutely works and is worth it.
I don’t understand why you keep telling people “it works quite well”.It works and is quite noticeable. However it often goes out of calibration (which I hear quite clearly even while playing the radio) and it won’t recalibrate until I shut off the radio for a few minutes.
“99 and 98/100’s pure” junk (recall very old Ivory soap commercial, anyone?)I don’t understand why you keep telling people “it works quite well”.
All indications I have seen, with people using the feature on this forum, are that it’s junk. So 99% say junk, 1% say it works.
Please, can any other user chime in who thinks this is a feature that does what was intended/advertised?
I can confirm that it works well in my April 22 build. Thing is that it is quite sensitive to many factors. And as mentioned, you’ll need to understand that it isn’t ANC. And only minimizes noises coming from the wheel wells. If any window is open, it won’t work. If your fan speed is somewhat high, it won’t work. If someone opens the door and enters then it temporarily stops working, and has to recalibrate - including every time its operation is interrupted. So it’s quite is limited in scope. Best to keep the audio options visible on screen to compare its function on/off.I don’t understand why you keep telling people “it works quite well”.
Right. More times than not, it won’t work - or worse, it adds noise to the car.I can confirm that it works well in my April 22 build. Thing is that it is quite sensitive to many factors. And as mentioned, you’ll need to understand that it isn’t ANC. And only minimizes noises coming from the wheel wells. If any window is open, it won’t work. If your fan speed is somewhat high, it won’t work. If someone opens the door and enters then it temporarily stops working, and has to recalibrate - including every time its operation is interrupted. So it’s quite is limited in scope. Best to keep the audio options visible on screen to compare its function on/off.
…they literally sold it as ANC. But I get your point.And as mentioned, you’ll need to understand that it isn’t ANC.
It works fine on my car. It's not earth shattering and it's too bad Tesla used language that left way too much to interpretation about what it would do. If it was a priced option I wouldn't pay more than $500 for it, and that's at least partially a bet on Tesla improving it over time.I don’t understand why you keep telling people “it works quite well”.
