There are two rubber stops under the hood. If you want to make the front center bit a little higher, you actually lower the rubber stops, as it's a concave piece of metal. Lowering the rubber stops, raises the front center, and vice versa.
Of course, look over the whole hood, just to be sure, there isn't some other reason for the front center being low, like maybe the whole hood is low.
