I need to replace a switch in my house. I want to turn off the power to the house first, not just that circuit. I'd prefer to avoid touching the service disconnect breaker as it is extremely difficult to switch back on, so much so I thought I was going to break it last time I did this. When I open the outside panel, I see the 200a service disconnect and a 200a breaker labeled gateway and non BLC. Will this top breaker disconnect power to the house from the grid or does the service disconnect need to still be turned off?
I plan to switch off all the other breakers in the BLC / non BLC first including the solar and PW breakers to eliminate power from any of those sources, then turn off the grid.
