I recently went through the installation of an ESV plug in the garage of my building.
To get the permit authorization you had to follow the National Electrical Code (NEC).
In particular, all the wires must be put inside a conduit, and so on.
Sample of ESVE Permit
Well, recently, a new tenant of the building had an Internet line installed by the ISP Sonic,
and the landlord recently contacted me as he was not happy about the work done.
So far Comcast has been used to provide cable TV and Internet connections.
The job was kind of professionally made. There was a connection box inside the garage
and then each apartment had its own wire hidden inside an conduit on the outside of the building wall.
With Sonic, the wire is running directly on the top edge of the roof and on each outside wall.
Honestly, this is not very clean, and if the roof needs to be replaced, the whole Sonic installation will have to be tear down.
I think that a cleaner installation would be to install the wirings inside the building instead of outside.
Using the elevator shaft to pass the cables between each floor and running the wires under the ceiling.
Well, here are some pictures of the installation, I let you judge.
- So do you think that there is a way to make a better and cleaner job?
