So i am working on installing an aftermarket sub and amp like many others here.
Pre-install research:
I have had my tesla 3 years and did my research before embarking on this project. I read many threads on this forum, Reddit and DIYmobileaudio.com before attempting anything. I have installed several audio systems on my prior ICE vehicles, this is my first EV audio install.
What am I installing:
I have the generally the same equipment as the post referenced in the guide below: the same LC2i pro, same Stinger SGP32 relay and same resistor (RX24 200W 2ohm Amazon.com ). Not sure where I went wrong but after having it hooked up and not turning on, getting multiple error messages and almost starting a fire, something wasn't right.
How did I hook it up:
I followed the wiring guide posted in this thread: Installed an amp and subs over the weekend . I am using 4 gauge wire for the primary amp power and I used 14 gauge wire with an inline fuse to hookup the resistor across the two main poles of the relay (I put a 30 amp fuse in the inline ruse holder, i should probably put a smaller one like 5 amps, will do on next attempt).
The only deviation I took from his wiring guide was that I tapped my remote turn on to the 12v red wire in the bundle at the passenger footwell for VC_Right instead of the 12v in the center console. This line has more power so i did not need a second relay to hookup before the Stinger relay, not a big difference, otherwise wired the same. I tapped VC_Right as shown here:
How'd it go?
So what had happened was... once I hooked it all up, and tested with a driver in the seat... the amp and LC2i were not turning on which was strange because my multimeter was showing 12v at each of the device power terminals.
I got several error messages on the Tesla screen:
VCFRONT_a552 - Condition detected with a vehicle controller
VCFRONT_a192 - Electrical system is unable to support all features
BMS_a063 - Unable to charge
VCFRONT_a180 - Electrical system power reduced
So I went inside my house from the garage to grab my laptop which took about 2 minutes and got back to the garage and smelled something heating up. I had all the components sitting on a piece of board just like @thesuffering did in his photo in the wiring guide I followed. I quickly did a touch test to see what was getting hot before i burned my house down and felt it was the resistor so i clipped the wires to it real fast to defeat the circuit. I picked it up by one of the connected wires because it was way to hot to touch and the board was dark brown below the resistor in the same shape of it! It almost burned the wooden board, had it got any hotter it would have. Thank God it didn't because how was I going to explain that to the wife?!?
I was able to clear the errors by performing the full power reset (power down system, disconnect 12v battery and disconnect the connector right next to the penthouse connection for a moment, then reconnected and restarted the car and all messages were clear. I disconnected the primary amp connection at the penthouse for the moment until I can get some direction from those of you out there smarter than me.
So..... what did I do wrong? Did i get the wrong resistor or just a bad one?
How'd it go?
