So, I currently use mobile connector with NEMA 14-50 adapter plugged into NEMA 14-50 receptacle with 50 A breaker. I know one isn’t supposed to unplug the adapter from the 15-40 receptacle often, but can you frequently disconnect the mobile connector from the adapter. The reason I ask is that rather than buying a separate mobile connect and 14-50 adapter to take with on road trips, why not just disconnect the mobile connector from the 14-50 adapter, leaving adapter plugged in (turning off breaker of course) and take the mobile connector with you on road trip, along with an extra 14-50 adapter (a minimal $45 cost). Then when you return home, reconnect mobile connector to already plugged in 14-50 adapter and turn breaker back on. This seems a lot less expensive than buying a separate 14-50 adapter and mobile connector to always have in car. Is this a reasonable approach?
