Hopefully someone will have the TT-30 EVSE adapter but if not, you could get
this TT-30 to 14-50 adapter to use but YOU MUST MANUALLY LIMIT CHARGE AMPERAGE IN THE CAR TO 24A because it doesn't set the car automatically.
Edit: If you don’t limit charge amperage before connecting the charger, starting the charge, and during charging, it could cause damage to the campground equipment and pose a risk of fire. It will also only a bit more than double your typical 120V NEMA 5-15 charge rate.
