I’m in the glass industry. Laminated, or acoustic (which is laminated) are both correct terms. Double-paned is totally incorrect and could be downright dangerous/fatal in an automotive application if not tempered with vinyl baked in the middle, which makes it laminated. Going in circlesTHANK YOU for saying laminated!! You’re 100% correct in saying that! And YES, interesting that your VIN has laminated windows. I hope they start laminating the rear windows soon, too.
I’m in the glass industry. Laminated, or acoustic (which is laminated) are both correct terms. Double-paned is totally incorrect and could be downright dangerous/fatal in an automotive application if not tempered with vinyl baked in the middle, which makes it laminated. Going in circles.
I WAS in the glass industry as well, worked at Guardian Glass so I know the correct terms as well![]()
We got 629xx and no laminated windows but for safety I prefer the ability to break them to get out of neededI know it makes no sense but have almost picked up a Y with 62xxx and laminated windows.
Are there plans for the rear windows to be laminated as well?
Can you please measure the thickness of your laminated windows? Trying to figure out if they will retrofit without any other modifications to the front doors. Thanks!
Great news, happy for you!I know it makes no sense but have almost picked up a Y with 62xxx and laminated windows.
That is strange, my vehicle build date is 10/18 and VIN is in high 636xx.Great news, happy for you!
I have a 62xxx vin also. MSM, build date 10/18. What is your build date and color?
Taking delivery 11/7.
So laminated front windows are 2mm thicker. Interesting!! Thanks for the info!!This was MSM as well, do not know build date, picked up at Tyson’s in Virginia.
I measured the thicknesses, tool says .1mm resolution, .2mm accuracy. It was 3.9mm in back, 6.0mm in front.
