D Dexmot74 Member May 14, 2019 30 12 Langley Dec 31, 2019 #1 Dec 31, 2019 #1 Can anyone else confirm this no longer works with 2019.40.50.5? I can wander all over center lines etc and it never goes off. Did something change?
E ewoodrick Well-Known Member Apr 13, 2018 8,053 6,062 Gainesville, GA Dec 31, 2019 #2 Dec 31, 2019 #2 Are you wandering across lines across lines or turning to cross them? It doesn't engage if you turn to move over them. I haven't noticed in current releases, but in previous releases it did work, but was persnickety when I tried to make it work.
D Dexmot74 Member May 14, 2019 30 12 Langley Dec 31, 2019 #3 Dec 31, 2019 #3 Drifting over, hands off wheel. Could make it go off all the time before. Never now.
CMoZ Member Aug 23, 2019 257 316 BC Jan 1, 2020 #4 Jan 1, 2020 #4 I've never been able to get this to kick in. Trying since September
J jc22zhao Member May 14, 2019 69 34 Toronto Jan 2, 2020 #5 Jan 2, 2020 #5 I still have it working on my SR+ on both 50.1 and 50.5 versions.
wayner Active Member Oct 29, 2014 4,317 1,827 Toronto Jan 2, 2020 #6 Jan 2, 2020 #6 Dexmot74 said: Can anyone else confirm this no longer works with 2019.40.50.5? I can wander all over center lines etc and it never goes off. Did something change? Click to expand... Model S? Model X? Model 3? Perhaps you should specify which car you are referring to - or at least put your car(s) in your sig.
P P3dStealth Active Member Nov 12, 2019 1,517 1,769 USA Jan 2, 2020 #8 Jan 2, 2020 #8 Mine works. You gotta really let it happen though.
Kappelan Member Jul 23, 2019 281 142 Greater Toronto Area Jan 2, 2020 #9 Jan 2, 2020 #9 I have it working for me. A few times I encountered sort of out of road correction and emergency braking.
PianoAl Active Member Dec 15, 2019 2,973 2,560 Far Northern California Jan 4, 2020 #10 Jan 4, 2020 #10 Tried it for first time today (New M3), and it didn't do anything.
D Dexmot74 Member May 14, 2019 30 12 Langley Jan 4, 2020 #11 Jan 4, 2020 #11 I figured it out. When coasting over line I had to make sure I'm not touching either pedal and bam it worked everytime.
Yoona NEWBIE Trader May 3, 2017 2,580 17,530 Canada Jan 4, 2020 #12 Jan 4, 2020 #12 The steering vibrate still works, but the chime never worked since day 1.
S Stan K Member Apr 14, 2018 82 57 Toronto Jan 5, 2020 #13 Jan 5, 2020 #13 My used to correct the crossing over the line, but lately is not doing it. So maybe this has to do something with the latest update. M3LR
PianoAl Active Member Dec 15, 2019 2,973 2,560 Far Northern California Jan 5, 2020 #14 Jan 5, 2020 #14 Dexmot74 said: I figured it out. When coasting over line I had to make sure I'm not touching either pedal and bam it worked everytime. Click to expand... If that's it, that means that if you're not using cruise control, it won't work (because your foot will be on the accelerator).
